AFC-SplitSecond PSC1 Map Library
if your on windows 7 then you dont need drivers for sure, if your on windows xp then i doubt you need drivers. if your on mac then good luck being compatible with 85% of the world (wiggle)
My netbook which I use for tuning is on XP and the R4 software works with XP and older only.
both cars have MAP sensors
they are just not used as EMS use MAP sensors
they are used to check vacuum and intake manifold pressures.
both N/A and Turbo cars have them.
im running it in windows 7 in compatibility mode, runs great. but then again compatibility mode is a 700 megabyte download and your basically downloading windows xp and running it within windows 7. but its alright my laptop can handle it. i think compatibility mode is only available in professional and ultimate editions (i get professional for free from my school) so dont try it at home kids unless you do your research.
if i disconnect my battery to reset my ECU does the SplitSecond reset as well? like would i have to reload the map onto the unit? or does it have its own little battery to remember s*** like that.
So can I do anything if I have windows 7 premium?
one thing I did notice though is that the stock supermap that comes with the ssafc when you get it from PG at least, doesn't come with the correct Option settings stuff, so besides when you first get it, and change the settings, but after that you don't have to change it till when you want to
Ok so I am having some problems getting my computer to connect with my Split second. When I try to connect to the split second it would just time out after the 10 seconds. Anyone have any tips or suggestions?
check what com its on, i had the same thing, also if your using windows 7 you need to run it in compatibility mode which as we just went over is only available in windows 7 professional and ultimate editions
anyone have a map for these mods:
turbolife FMIC
port/polished intake manifold
SRI
stock boost
Thanks.
I know this question may have been beaten to death, but I'll ask anyway. Which map is best for stock boost level, CAI, hard pipes, upgraded exhaust mani, upgraded smic, upgraded cat-back exhaust and running one cat? Someone with similar mods was told the stock super map was good to run, but they were gettin 10 afrs, which is what I get now without the ssafc. Is there a map modified to have 11-12 afrs?
How do I save the tune as if I wanted to post it here? (how do i save it as a file to my computer.
^^ and wagon, could you link my map that I posted to the first page, I linked it a couple pages back, it's a good tune so far, if anything I could update it a little but so far so good, thought it could help some others , thanks
oooohh, damn.. how do you get an msp mod revoked? or did you just not want to be one anymore? if you don't mind me asking, but anyways I will do that at some point, thanks
to be honest, I have no idea. apparently complaints were lodged against me (I believe because I was being a stickler about being on topic), however I didn't bother trying to pursue the issue as it happened the same week that my grandfather passed away. I tried to get it reinstated (primarily to keep this thread updated and navigable) but received no reply from Antoine regarding it.
