MikeHTally
- 2008.5 Speed3, 2006 Chrysler 300C, 2003 Ram 1500
And it is, the fans don't run on the highway. They windmill, just like the e-fan on the truck.well, if your brick of a truck is fine, then the speed3 should be honkie-dorie.
Think about that a minute. Preventing the evacuation of air while it's pouring in through the grill at 1,000's of cfm will raise the pressure, not lower it.
somwhere, bernoulli is spinning in his grave....
as the air passes past the "splash guard," it sucks air out of the engine bay, HELPING to create a lower pressure zone in the engine bay. removing that panel allows the air to circulate up right behind the raditor allowing the pressure behind the radiator to equalize with the air in front effectively STOPPING the airflow through the radiator.
you know this for a fact? have you sat in your engine bay while cruising down the highway to monitor the fans?
Jeez, people. This is pretty simple stuff. Manufacturers have for years looked for ways to reduce load on the engine. The mechanical fan takes a LOT of power to turn, so they looked for ways to disconnect it. First, it was the centrifugal clutch on the fan, designed to have the blades turn loose of the water pump at a certain rpm. Then they put thermostats on the fan hub and clutches to accomplish the same purpose. Now it's possible to install a fan that only comes on when needed, further reducing the load on the engine.
No, I don't have to sit in the engine bay to see if the fan is running. I rigged a LED on the dashboard so I can tell when power is going to the fan. It only kicks on in traffic. The 'stat in the Ram opens at 180 degrees. I have the fan controller set to kick on at ~200 degrees. The e-fan on my Ram is capable of 3,300 cfm. The air through the radiator is WAY more than that, except when I'm in traffic. Ask your favorite knowledgeable auto tech if the fan runs when you're on the highway.
As for Bernoulli, I suggest you go look at the belly pan and see which way the air will move when it encounters the NACA ducts.
I'd like to see some real facts about the low-pressure zone behind the radiator, since there are so many thousands of cubic feet of air provided by the forward motion of the car. The low-pressure zone could only be produced at speed when it would have only miniscule benefit if any. It would actually produce slightly more drag, which would adversely affect mileage to a tiny degree. With the government regulations on fuel mileage, ANY drag would be a drag.
Volvo also suggests that the pan aids in cooling efficiency by forcing the airflow across the entire engine compartment.
I logged before and after.
All temps went down noticably with pan ON.
There is a reason race cars run them. Air turbulance hurts in many ways. Temps just being one that we'd worry about, since none of us are fast enough on a road track yet to worry about the other effects, lol.
Run without it for all I care. I was going to since my car doesn't get driven in bad stuff. But after logging, no way. It stays on. And it isn't a big deal to take off; I don't see what all the fuss is about for an extra minute or two TOPS. But hey, it ain't my car, so have at it.
Well, "Volvo suggests..." is hardly definitive. A post from another forum can be dismissed as it is very likely not in any way scientific. As for the "cooling airflow" item, notice it mentions only the fan shroud and the recirculation shields. "...Increasing airflow by speeding up the fan, by providing an improved fan, by providing or improving the fan shroud, by reducing air restrictions in the grille or engine compartment, or by providing recirculation shields to prevent air from bypassing the core, will all improve heat transfer and cooling."
Obviously we disagree. My position is common sense: if air is roaring through the radiator at any speed above 30 or so, it will overwhelm any "negative pressure" created by a belly pan, if such pressure drop exists, which is doubtful, considering the scoops pulling air into the engine bay by the pan. You mention Bernoulli - his formula talks of static pressure and dynamic pressure. I suspect the dynamic pressure of air through the radiator at 40 mph is WAY more than any pressure drop caused by the pan.
