bout to bite the bullet on this....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260581189950&ssPageName=STRK:MEWAX:IT
gave mine a quick rinse today, also snuck my way into the shop at dads place and put it up in the air to check the endlinks, rear diff mount, and anything else that clould be causing my mystery noise, nothing loose or broken....
i must have missed your other post. is your mystery noise coming from the rear? i have a mystery noise coming from my rear.
my cars rear that is.
according to the cobb atr info. the stock maf becomes inaccurate above 22 psi and suggest not running any more boost than that on the stock maf.
you might wanna datalog and make sure you not making 20 some psi of boost at like 3500 rpm. thats a little dangerous for the stock bottom end.
So thats a no? Even with the fmic and meth it wouldnt be good? I am assuming this will of course kill the turbo after time. But 19-20 already seems pushing it. But 20 psi felt so good.
On the way home tonight I did some logs. Well on my 3rd gear wot I blew a hole on my coupler coming off the turbo. I think the heat from the manifold being soo close caused it to become very soft and the 20 psi just blew it out. Thankfully I have a spare to replace it with.
Well mazda just called said $3400 n tax to replace turbo not covered under warranty, warranty expired on june 4th ffs and said not covered under powertrain.
