Short explanation.
Car ran normal. Put on a 2.5" exhaust from the flange back. Took a look at the 2nd cat. EMPTY
Uploaded with ImageShack.us
Car ran better.
Over the weeks the car eventually lost its umpf, and bascially moves as stock or worse than stock.
Thought the main cat was clogged. So today cut out a section of the cat to knock it loose and gut it. Well, NOTHING was inside the main cat attached to the header.
In this pic is speaker wire fed through the 1st o2 sensor out the bottom back of the "cat" through the hole that was cut. Nothing there.
The first point of blockage would be either flex pipe, or the race muffler which has a 1" or 1.5" straight through core. Both clean and free of any obstructions. Which leaves me to thinking that both these cats blew out before I ever put the exhaust on.
For s**** and giggles I thought I would pull the spark plugs out
Spark plugs are in order from looking at the front of the car, passenger to driver side 1, 2,3,4
here is passenger side #1. Oil is on the threads, but it is CLEAN oil. I assume from when I poured it in I spilled some and it gathered there.
#2
#3
#4
The main sensor before the headercat
The code I had is PO421
But i have no f'in cats, which means a sensor would be bad correct? Pre cat or post cat?
The tip of the pre cat sensor is white is that normal?
#2 spark plug had white build up on the tip, indicating?
Im really at loss for what this cars problem is. The spark plugs were dry, so there is no indication of water or fluids on them.
Its a 2006 3 s with 52,400miles, mostly town suburb driving the trip computer says I get 26+mpg.
Before all this was happening I could easily move about at 3k rpm, now I gotta get her up to 3500-4k for the same movement but the car sounds funny and doesnt have that get up and go power. Indicating lean?
Someone help me! Im lost
Car ran better.
#2
#3
#4
