What have you done to your Miata today?
How much can you fit in those? I'm torn between that and the four piece set. Put my h&rs on yesterday at the alignment shop today
i was seriously suprised by how much they fit....got enough clothes for about 7 days worth plus all my toiletries, and i still have quite a bit of left over room. plus there is still a bunch of room in the trunk for more stuff. I like that the material is real thick and that the zippers are heavy duty.
Installed new wheels/tires over the weekend. From those ugly hubcap steelies to these. They're stock off a '96 Integra and painted a black/gray color. They were cheap and came with Falken Ziex ZE912's.
Stupid question time:
Is the 1.8 from 99's same as the 1.8 from 94+? and would a 6spd trans mount into a 5 spd car?
Re the 1.8: No. IIRC the 99-00 has higher compression and a VICS manifold. The 01-04 had higher yet compression, the VVT head, and a main bearing support plate. Not sure but IIRC they also had the VICS manifold as well.
Re the 6 spd: Yes, but you need a 6 spd flywheel / clutch / pp IIRC, due to the different input shaft spline count. But I don't know why you'd want to do that. 6th gear is actually shorter than 5th gear in a 5 speed.
i'm looking at a 99 1.8 with trans installed still and ecu for $1000 local is why i ask
not worth messing with? I KNOW i can get a 94+ 1.8 for cheaper from my local buddy that buys wrecked miatas
