boostedprotege
- 2003 mazda protege dx/2003 mazda protege5
i'm pretty sure he was still forged wit lower compression then too not on a stock engine lol
and this is what aem says
AEM Water Injection Kit (now includes the upgraded 30-3014 pump!) If you have a boosted car or turbo diesel truck and want to safely increase the amount of boost you run, the AEM Water/Methanol Kit should be on your list of things to buy. For boosted cars, the Water/Meth kit helps two ways. First the atomized water drastically lowers intake temps, allowing a cooler charge into the cylinder. Secondly, the Water/Methanol/Alcohol mixture acts as an octane booster, reducing the risk of detonation and allowing higher levels of boost to be run safely. In diesel applications, if you are running a chip, the fact is you likely have higher EGTs. While those mean more power, they can also cause premature wear on your turbo. AEMs datalogging shows EGTs drop drastically when running a water/methanol kit. The kit is simple to install, and includes many features other kits charge you extra to get like a large tank (1 gallon is in the base kit) fluid level sensor that includes a boost-safe feature that can reduce your boost if you are out of water/methanol. Three jet sizes give you a wide range of tuning potential - check out our video above for an overview and to see the different nozzle sizes in action
so it does have a safety switch to only lower your boost when meth is out so your right on that part
