marcs_sp20
- 02 Mazda 323 Astina SP20 (P5)
what could be the vibrating sound coming from my car since my magnaflow was put on. around 3k rpm and some points lower and higher there is some sort of vibration metal/metal sound that is somewhat annoying. not sure what it could be. any thoughts???
had the same problem when I got my new muff put on.. it was touching on the rear sway bar, and when I had it moved forward, the pipe over the axle was then touching the join of the fuel tank, also had a clunk (which was from bad mounts) where it also rubbed behind the rear bumper on the heat shield...
So get out and have a looksie underneath
