irishkev90
- 1998 Mazda Protege LX
They have everything for the BP, nothing for the Z5
The Z5 is like the child nobody wants, haha.
Thanks manIf the protege that ın your sıgnature ıs yours,that's excellent !
I love 323f series..
No pics or links Anthony?
did you tune the vaf? and yeah, the gr2's are softer than stock. when it is time to replace go with these :
http://www.summitracing.com/parts/FMS-M-18000-Z2/
you're going to need silicon sealer and a small flat head. pry the door off the top, while the car is on depending on the settings of the rx7 you need to turn it either way. go until your idle smooths even after blipping the throttle. you have enough teeth inside (you'll see when you open it) to get pretty hard core about it. you can also advance the timing at the distributor and get a couple of hp'ssss out of it. Remember to run higher octane if you do that
