Cherryvodka
1. One of the biggest myths is that the car can't make power due to fueling. With upgraded fuel pump internals there's plenty of fuel to more than 450whp and beyond.
2. Stay away from the ATP turbo's if you want to make power, they just don't flow nearly as much as their T3 counterpart. The exhaust housing chokes those turbos. For example, I doubt a ATP gt3076r could make 415whp unless the exhaust housing was ported.
3. Even if you don't go big turbo run methanol injection. The stock tune is pretty agressive timing wise as stock/near stock cars tend to knock significantly. On its own you can use a mixture of methanol injection that is suited more for lowering BAT's(ie. more methanol) or cooling the combustion chamber (more distilled water).
4. Cp-e SB/Flashes is/are the best tuning option available for the car.
5. Buy a good intercooler
Old dyno (since this dyno, timing was increased, methanol injection was added and boost was increased to 24 psi)
