use a spark plug gap tool. theyre like 50 cents
that only tells you if its gapped right but it does not close the gap if there is too much
Used the gapper to squish the gap to where it's needed. And most have a hole on them to open if you need to.
Dropping the flywheel off today. How hard is it to replace the rear mainseal while it's out. Flywheel has no oil on it but the bolts do. Was also thinking of getting the LSD welded but feelin intimidated by the complexity of the gearbox disassembly to get to said LSD.
if you're not comfortable doing it, pay to have it done... if I could afford the down time I woulda... but I'm more than glad I went welded, otherwise every step on the go-pedal comes with a cringe.Used the gapper to squish the gap to where it's needed. And most have a hole on them to open if you need to.
Mother F'in F'er! I don't think i could ever recomend a Xcelerated Concepts Hood to anybody. They won't take it back unless i pay shipping ($160 or more) and they can't seem to understand a simple concept of "Send me a new latch without any holes drilled in it and leave extra steel on the sides so I have room to work with."
My plan was simple. send me a new latch without the holes drilled out, i figure out where it needs to go, drill the holes on the latch to match the existing holes on the hood and TA DA! I have a hood the closes properly and the strength of the latch isn't comprimised.
The first latch never got to me and the secone has holes already drilled out but of course they don't line up to what is already there. Maybe third time's a charm? so much for having it for MWMF, thought i'd have plenty of time when i ordered it towards the end of january.
end rant/
think i might quit my job so mooding and driving the msp maybe less in the future
Wait wait wait. Your telling
me the msp had a go pedal? =O!
and sometimes it even does invoke the prescribed "go" motion!
just slot the hood latch mount holes so you can move the latch instead of the catch?
washed...damn street light
the protege 5 and MSP headlights are the same size correct?
