dougefresh_
- 2006 MS6 wwp
So I flashed the stage 2 TIHSF 93oct map about a week ago, and my fuel trims maxed at +6. I calibrated the MAF (thanks for all the help smoker!), and my LTFT's are now within +3, and I'm fine with that.
I'm running the stock fuel pump, and mods in my sig. I only had KR of 0.35 at WOT a few times, which I thought was okay. My fuel pressure hasn't dipped below 1200psi, but it's cutting it close (fuel pump is next to be safe). My afr's ran a little lean near redline (I shift at 6K, but I think there a bit low? Dangerously low??)
I attached an edited, easy to read excel file of the 3 pulls below the graphs. I would GREATLY appreciate some input as to where I need to go next, or what I need to keep a close eye on. I'm learning as quick as I can, but it's only been a couple of weeks, and it's a lot to take in.
Here are the graphs of the hp/tq, as well as the PSI/RPM/AFR graph.
I really appreciate the help! I've been reading the ATR manual a lot. There's a lot I don't understand beyond calibrating the MAF, lol
