Has anyone found a rear diffuser to replace that dull black piece?
ok, if found these 2. Now, this was the first one he made and the guy he made it for was kind of being a dick so he didnt end up completing it.
I'm pretty sure you can feel rear flying going over 100mph...
hope material is thick enough so those ribs wont flex on high speed too..
would be nice to compare aero test results of this to stock ))
I am still surprised that there is not a rear diffuser that is functional for this car, i mean there are plenty of MS3s that would buy one, and no doubt some Mz3s that would buy one as well.
I would be all over a functional diffuser, as well as some "conservative" dive planes for this car.
Not a lot of companies have access to a wind tunnel......
WOW, Here is the PERFECT part $$$$$
and just that piece. as in leave the reap bumper alone, except for that ugly rubbermaid lookin, wax residue retaining center part (pukey)
It even comes with its own third brake light.
I think the manufacturer is english
Turbo23 is correct. Rear diffusers have an almost negligible effect unless the entire underside of the car is a flat sheet. Also for diffusers to be effective they cannot slope up at a super steep angle. The one we churned out at work for a top speed salt flats car I think was between 7-9deg. I think I remember being told that once you get over 14deg flow separates and the piece doesn't work.
With all that said, I think the DG piece looks great, but I doubt it helps from an aero standpoint.
if its dull there is a product in pepboys called "back to black" and it helps restore faded black plastics like that one or any other pieces also it shines it.
I use this on that part every time I wash the car. Under the front lip on the black piece too.
I'm anal and use a cheap tire dressing to spray the wheel wells to make them nice and black too.
When I'm done, my car looks like it's never been driven. :)
Meguiars' Trim Detailer works well also. It's a little thicker than the Mothers' which I think makes it a little easier to work with. It also gives more of a shine in one application - at least when I use it.
Good to know. I've never used it but will keep an eye out for it.
