Jaysanooch
- 2003.5 Msp
This is my winter map....you need to view this under "gauge pressure" and not "vacuum pressure" since I run the FTC version. If you wanna try it out...copy paste it or something.
My AFR's @8-9psi spiking 10psi never go past 12-12.2 and my wideband is pretty stable. This is pretty conservative and safe under 10psi. Pay attention to the linear pattern....very simple and it works. It's set up to be progressive to boost.
Trying to tune each cell individually is just ridiculous...especially since the jump in rpm's between cell's is by 500rpm. I used to kill myself data logging and go back to adjust etc etc. I had a code reader moment one afternoon....and I made this linear pattern fuel map for fun. I tried it and it was very smooth and consistent. I've had to play with a dozen times but when I change something, I change it all diagonally.
Anyway, maybe it's just me but it's work nice.
