xDJ DUBx's 03.5 Pure White LX-T
PM 323. I found a good one real cheap for him. I hope he saved the site. I will need it here soon too.
lol i'm pretty sure its needed to tune idk y they wud throw it on there if it was for loks haha but then again you never know
Just got word on the trans, its all packed up and ready to go, should be dropped off wednesday to get her on the way
For future reference, does it matter where the WB bung goes? I was going to put it right where the second cat is that way the wire comes out the firewall and goes straight down, plus I could get my high flow cat welded in at the same time, is this too far from the motor?
I mounted mine after the second cat, and it was only off 00.1 from the mustang dyno!
Don't get me wrong i'm sure the cat's affect the readings. The o2 sensor will also last longer being further away.
Vac block and motor mounts are a must, until then the trans will go in with the ss clutch line, ssafc, and wideband. Once all these things are done, I'm just gonna sit on my money while I start the sunroof and body project.
Well sunroof from the p5 is gonna go in, gonna either convert my antenna to a p5 setup or fully delete it, shave trunk, repair all the scratches and stuff, then repaint the whole thing in CWP ;)
