Yes but it will save you the cost of having to buy a replacement HID kit down the road, here is how I wired mine:
I have an aftermarket battery tie-down so yours might be slightly different
The relay is on the left, it comes with a bracket to bolt down wherever you want it
Close-up of the positive wire on the positive terminal
Close up of the ground for drivers side ballast and misc. connectors, make sure the location where you install the ground is stripped down to absolutely bare metal
Drivers side zoomed out view
Wiring tucked behind vanity cover
Harness zip tied to another connector for support
Another zip tied location for support
Close up of passenger side area
Passenger side ground point
Passenger side zoomed out
This isn't the cleanest install ever but everything is easily accessible in case anything happens.
