Post a picture of your MAZDASPEED3
Some Track day pics I found.
http://www.bcracing-na.com/HEIGHTADJUSTMENT.htm
i found that somewhere. i read that and realized that ive been doin it wrong. hope it helps. when i first got the BC's i also was confused as hell too.
I have been doing that from the get go, so I am fine there. But what I need to figure out, is how to adjust the rear ******* shocks. Does anyone have a HOW-TO with pictures showing the adjustment of the rear shocks? My rear springs are already set, but I can't figure out how I am supposed to set up the rear shocks. I have the spring as low as it can go, if that helps anyone that can give advice. The shock itself has a long threaded-bolt on the bottom that goes through a hole and it has a nut on it half way up that can be tightened or loosened. WTF is this thing!?
O ok i see where youre stuck. ok loosen that nut and spin it down the threads. then what you do is spin the whole shock body down the threads. this is how you do it. you see at the bottom of the shock its like a circular but the sides are chopped off (right above the threads/nut. its gold). then use a big open ended wrench, slide it on the flat part of the gold thing and use that as a handle to turn it. spin it down until you start feeling tension or something like that. then spin the nut back up to tighten it.
lmk if that made any sense.
thanks man, when it warms up and I get my new tires put on and get my wheels painted, I am definitely gonna try to set up my suspension in the rear better.
mazda 3
hi everyone im new here,tnx.(yes)
Is it me or does the door block the opening when "open"? Gotta be a contorsionist to get in?
here is my ride (drive2)
while there are a of highlights, I think my favorite part is the huge VERTICAL DOORS sticker
Yeah for real, I am glad that the sticker was there, I had NO CLUE what kind of doors those were. I was confused at first, but the stickers really helped clear up the confusion! (unamused)
