- 2010 Mazda5 GT
I've done three oil changes in the past year with PP 5W-30 and all of them required between 5.5 to 5.75 qts. with filter. The manual states 6 qts. when changing out the oil w/filter. Yesterday, I made the switch to Rotella Synthetic 5W-40 to hopefully help with the smoking turbo issue. Who knows when and if Mazda's resolution will surface for this. Oil level on the dipstick read right at the MAX mark.
I let the old PP 5W-30 drain for a good three hours. At that point oil was dripping every 15 seconds or so. I figured that would be enough. I put in 6 qts. of the Rotella and the oil was below the MIN mark. I thought that was odd. Went out and purchased one more qt. this afternoon and put the entire bottle of that in. I put in a little at a time to monitor the level (I waited 10 -15 minutes between each pour so the oil could settle into the oil pan). At the end, I just poured in the rest and now it's right at the MAX mark. There are no traces of oil leaking that I can see on the floor and I looked all around the engine and oil pan today when I had the car up on ramps.
Anything I should be concerned about or looking for? I thought this was very strange and caused me to worry since I had to add an extra quart in (confused)
