That's diesel-rich, lol. Do that alot and you're in cat-melting territory.
Another thing to consider is that while your AVERAGE afr may be 12:1, indicated by your DH, the individual cylinders may be quite different. One hitting 13.5:1 and one 10:1 will average at around 12 but, one is on the way to melting down. You've got to leave a little room for flow variations between the cylinders.
I haven't flowed this manifold but, I'll give you an example from another platform. The factory lower intake on a 5.0 Ford's worst cylinder (#5) flows about 70% less than its best cylinder (#8). So, #5 was pretty much a dead hole given how much fuel was flowing through it without air, 8 was running a touch hot because of too much air. All's well for the ECM on the AFR at the downstream O2 sensors, though, at least as much as narrow band sensors could tell.
