I got my new Clarion VX409 installed this weekend
are you sure the tires are stretched and not tires with a rim guard lip on them?
The tires are stretched quite a bit. This whole wheel selection was quite the experiment. I knew what it would take could get the look I was going for, the tire size was the x factor. The fronts fit great, no rubbing at all. The rear rubbed on hard turns. So I rolled the again giving them a slight pull this time. No I have ZERO rubbing issues. Making me confident that next time around I can shove some more meat in the wheel wells. I was just looking to push the envelope and try something new.
oh i cant tell by the pic cause of the light reflecting off the wheel but with those numbers, then yeah that is stretched
I thought 8" rims were a stretch to fit on the MSP. What kinda spacers and setup did you use to get 8.5" to fit?
No spacers at all. The wheels are 8.5 wide with a 30mm offset.
On the inside between the strut and the wheel I actually gained 6mm of clearance. The outside edge of the wheel comes out 44mm farther that the stock wheels.
Yeah, the aggressive wheel thread got me thinking.
http://www.mazdas247.com/forum/showthread.php?t=123735977
After that I started reading about the style quite a bit. I even tried on a set of RPF1's off my friends MS3. They were 17x9 40mm offset. The Barely fit the back, and didn't clear my front brakes.
Inspiration.
http://www.Hellaflush.Com
http://www.stanceworks.com/
http://www.rimtuck.com/
http://flushstance.ccwheel.com/
http://www.tyrestretch.com/index.php
I used this tool quite a bit a well.
http://www.1010tires.com/WheelOffsetCalculator.asp
So... Found out how great Kumho Escta MX's are in the snow/cold.
Yeah, not so much... Breaking the fronts free when you roll into the throttle in 2nd gear, on dry pavement, is pretty severe...
I don't like Kuhmo's because every one of their tires I've tried or driven breaks free wayyyy to easily, regardless of dry or wet pavement.
