FINALLY got my SS AFC, vacuum block and vacuum hose installed last night! Took the car for a test drive after and DAMN! It definitely pulls harder now, and my wideband read in the 12's under full boost. However on my way home it started dipping into the 10's again :( so I guess it's tuning time. Only problem my friend ran into was when he lost a socket...but in searching for it he found 3 others under my passenger front seat hahah.
What are your mods? cause with my mods (see sig) I am at 10.0 unless I up the boost to 10psi then it changes and goes into the 11's. I am also on the stock supermap.
turbolife, injen sri, apexR1 2.5" catted j-mid, greddy sp2, afc, stock boost is 6psi
wel i replaced a wheel bearing for absolutely no reason. i have no idea what is wrong with it
if its a weering(is that even a word? lol) noise check your tires for abnormal wear! If you do have adnormal wear look at your struts and see if they are leaking. If so time to replace that strut. I just went through that with the gf 6.
Edit: Wrong bearings.... I say that because of his previous post in this thread... Just look at the thread name.
http://www.mazdas247.com/forum/showpost.php?p=4920921&postcount=43
Just installed FMIC. YEAH!!!!!!
