- 2008.5 MG Mazdaspeed 3 GT
boost pressure is directly related to how much air the engine can breath in at any given rpm vs how much air the turbo can move.
Assuming 100% volumetric efficiency
Air flow rate = (displacement)(rpm) / Strokes * conversion factor
MS3 - 2.3 liter @ 5800rpm
AFR = 140ci*5800* / 2*1728 = ~235 ft^3
GTI - 1.8 liter @ 5800rpm
AFR = 122ci*5800 /3456 = ~205ft^3
They do not push the same amount of air at a given rpm
To go one further:
again assuming 100% VE
boost = (max cfm of turbo/AFR)*14.7 - 14.7
MS3 - (X/235)*14.7 - 14.7 = 15.7psi..... x= 486cfm
GTI - (X/205)*14.7 - 14.7 = 15.7psi...... x=424cfm
the x values are how much cfm the turbo is required to push to achieve 15.7psi
again they are not the same. This does not account for the engine volumetric efficiency, engine design etc. which in either case will not be the same for both engines.
so 15.7psi is not always the same cfm. This further proves that the K04 is undersized for the 2.3.
and to show it is in fact still making power above 6k please see attached dyno chart and datalog. power is beginning to drop at 6100rpm, but that is due to flow limitations of the engine itself, the turbo is still pushing 18+psi at 6200 in the attached datalog
To go one further:
