It's all linear, so if the throw is 40% less the force will be 40% higher.
This I do not agree with. The throw and force are not related.
The reality of the matter is I'm not shifting from the arm on the transmission. I have a giant lever in the car. Imagine if it required 40-50% more force to shift, you think the 17 folks that have bought it would be happy? They love it!! Oh yeh, the weight has nothing to do with it either.
The additional force required is minimal. To me it feels more defined. No more hunting for gears. Yes it requires more effort but not in a negative way, in a good way. The smaller weight is required because the radius of the arms movement is less witch causes the arm to move faster. The larger factory weight was too much and would cause a bang / clunk and some rebound of the shifter after going in to gear. Reverse is no issue.
As for the boot, It does touch, but I think rub is to strong a word to use. I include a grease packet with the kit to lube the area where the boot touches. The cable inside the boot is not rubbing anything. All I can say is I have almost 3500 miles on mine and there is NO, I repeat, NO indication of wear on the boot. I have lubed it one additional time during an oil change.
This design is much different then how the folks in this thread are making them. There is no additional force or stress on the transmission or the cables, and certainly no binding of any part.
I hope I've answered your questions.
Go get a spring scale and measure the shift force for yourself if you don't believe me.
Every review of any shifter weight will confirm that it does affect the shifter feel. It's more inertia to rotate when you're shifting, to shift at the same speed with the lower inertia from a light shifter weight requires less force.
It's all basic mechanical physics...
Well you don't understand reality...
It takes a given torque to shift into a gear. Torque = Force*Lever Arm Length. When you make the lever arm shorter for a shorter throw (which is what the plate does) the force increases accordingly because the same torque must still be applied, but through a smaller lever arm.
Imagine tightening down a bolt, it's a lot easier when you grab the wrench at the end of the handle rather than right next to the bolt.
From the looks of the pic, The boot on the shift linkage will (and looks to be already) rub on the joint (or w/e you want to call it) beside it.
Nobody has really stated if there's any rubbing as well... is it wearing down on the rubber boot?
Or am I missing something here...![]()
