 - 2017 CX9 GT AWD
I have a 2008 Mazda5 Touring with around 16k miles. Been a great car so far.
However, a strange thing occurred the other day. After driving for about 3 hours with the AC on and the fan-speed set in the mid-range area, I noticed that it started getting a little warm in the car. When I put my hand up to the vents it didnt seem like it a lot of air was coming out. I cranked it to the highest fan-speed setting and it was still barely coming out, just a tiny bit of air flow. I cranked the fan-speed up and down; turned the AC on and off; turned the Recycle on and off; turned the Auto Climate Control on and off; and I cycled through the various air direction modes. Nothing worked. It was as if someone put a sheet of paper between the fan and the vent so barely any air was getting through. The only thing that did work, though, was the rear vents seemed to keep the same air flow.
The only thing that fixed it (temporarily) was we pulled over for a few minutes and we looked under the hood. Seeing nothing obvious we started up the car and left and suddenly it worked again fan-speed working at full blast again. However, within about 30 minutes it started doing the same thing once again. When we got home after having the car off for a little bit I started the car again and the fan worked again. It has been working since then with the short 20 minute trips weve made.
Im taking the car in for an oil change and will have Mazda look at this problem. But, does anyone have any clue what this strange issue could be?
