newprot5fan
Hey all,
I have a torn passenger side motor mount insert. The front seems ok and haven't checked the others.
Now, the actual mount on the passenger side looks ok. Are the AWR inserts good enough to use or should the whole mount be replaced? The car is a daily driver (no racing), but I have alot of movement in the engine and the gear shift (it is a manual). Any thoughts if that is a good idea (it would be the softest mounts - 70 I think.
I know the debate on which mount has been done to death...right now everything is stock and am wondering a few things:
1. Are INSERTS in the passenger mount going to cause a substantial increase in vibes?
2. Which mount is responsible for the most vibration?
3. Are there 4 motor mounts (front, rear, pass, and is the driver one called the transmission mount or is there a separate transmission mount)
4. Should all be replaced if one is ripped (meaning the other ones are going to go soon )
Thanks for your answers.
