So I'm doing the timing belt and trying to take the crank pulley off... But I have the UR underdrive pulley and it doesn't have those two bolt holes like the stock one does, is there any way of removing a pulley that doesn't have those bolt holes???
so this is the one that i have...now i do see that there some slots towards the back so i can see if there are those on mine, but unfortunately i do not think that mine has the same thing...
i will take out the spark plugs though, i never thought about the compression issue.
so the engine still turns when i have the car in any gear, is this normal???
thanks for all your help!
ill post again if i cannot figure anything out!
so... i studied those youtube videos and tried it, first time, the bolt came loose! yay!
If you are thinking about the jagged (serrated) rim, don't mess with those spikes coz they are needed for the crank sensor to detect it's movement...
yeah, you put the gearbox in neutral, and if you decide to crank the engine to try and let the bolt loose, you will need all the power the electric starter has, so you do not want the compression to take all the power!!! Just be sure to crank it for just a second or so, coz the starter will have a hard time to turn, so it will be stressed and might burn out... Just do as they did in the Y/T video...
Yes, there is a flex and slack in the system, (it has to be that way, otherwise the system would snap if you dump the clutch or stall the engine)... the flex / slack is in the gears in the gearbox, shafts, clutch, dampers, so all added up, you can turn the crankshaft up to 360 degrees, while barely getting 1 degree on your wheels!
But as you continue rotating the c/s, you will eventually spin your wheels, BUT do not try to apply brakes on the wheels and try to undo the bolt that way, I had explained why in a few posts above this text... (1st page post #12)
Let me know how it turns out!!!!! -Show that pulley who's the boss!!!!
Well this is all fine and lovely for loosening the bolt, but how are you supposed to retighten it to 160 Nm? I presume the starter cannot be run in reverse? (nana)
What was the thread pitch of the 8mm bolts for the crank pulley - 1.25, 1.5?
the way that i tightened the c/s bolt is have one person tightening the bolt while the other holds two wrenches i think they're 23 or 24mm one on each of the camshafts... we got both of the marker lines to line up, so it worked! it just takes a lot of effort to hold the camshafts still...
t
my question is: i finished everything and took it out for a drive... but there is a noticeable ticking sound that follows the revs and the idle is quite rougher than before i did the timing belt. There's no vac leak, bad egr (i don't have one), or maf, they were fine before i did all this work on the car...
so the question is, if i was one tooth off when i put on the belt, how much of an effect on the engine would there be?
Gozz,
As a new member, I wanted to compliment you on an outstanding how-to. I tackled this job about 2 weeks ago and I couldn't have done it without your help; saved me about $850.
Two more tools I found very handy for the job:
- 3/8' ratchet with a swivel head
- 1 1/2" extension for 3/8" drive
Again, thanks for the help!
Only drain the radiator if your gonna change the water pump?
Hmmm, yes, that is a hard one...(uhm)
Well, you can always use an oil filter wrench hooked around the pulley...
(boom07)(smash)
And use my "magic marker" method...
Hi,
I'm doing the timing belt, roller, tensioner and water pump job per this post and threads. Great post and threads. Thanks! I've also been taking some pics and notes and have a couple suggestions and minor corrections. The new water pump and belt roller are installed, but I'm stuck on step #21. Here it is again (in quotes):
"21. Put the new tensioner and tighten it. (do not put the tension spring on yet!!!) This type of tensioners used on 1.8 and 2.0 proteges operates by a spring tension and auto-adjustment feature, meaning that even if it is tightened all the way, it will still swivel back and forth, as the spring pushes on it against the belt..."
If you were inside the engine looking at the back of the tensioner, you would notice the mounting large bolt hole, and a smaller "locator" hole next to the large hole. Here's a pic:
http://cid-0ba9610cbd3ba347.skydrive.live.com/self.aspx/Protege%202002/tensioner.JPG
Only problem is that there is no locator hole "pin" on the block to match up with that locator hole. So the question is, how do you position the tensioner before tightening up on the bolt?
Only thing I could think of is that since that other sources on the web say, "Check the tensioner spring length, if the free length is not 1.44 inch (36.5mm), replace the spring". That could mean install tensioner this way: install the bolt, but do not tighten it down fully yet. Next install the spring. The tension arm position will now be determined by the length of the spring (ie. the tensioner will fall freely counterclockwise but no farther then the length of the spring will permit). Is that what is supposed to happen?
I will appreciate your help on this.
Regards,
Brcobrem
