the shoes in the trunk might slow you down
Oil & filter change(Pennzoil Platinum-PureOne), Coolant flush & fill (Prestone), Transaxle oil (Mobil 1) and removed and greased rear bushings(no more squeaking).
Spent four hours up at the Corksport Meet. Here's the high point for me...
My first dyno!
Dynojet Dyno running Winpep7 software
Three runs; fourth gear; temp=69.4;humidity=72%;boosting @ 8.5 psi
Best Run 175.40whp / 175.77 Torque / AFR's= 11.2 @ 6k rpms
Derrick of CS said the humidity and lack of fans running during dyno really hurt the results; he estimated a loss of 8-10 hp due to conditions. (Or he was just being kind....) For the mild mods I have and stock ECU, I guess its not bad.
That makes me wonder. Since I have the autotragic without the tiptronic, am I able to dyno? I have 1,2 then D so I wouldn't be able to do a 4th gear pull. Would a 2nd gear pull be good or?
2nd gear would probably have to do... that'd be like a 3rd gear pull on a stick, so it'd be something anyway.
I got it figured out. i wondered if I could just push the overdrive button and turn it off and do a third gear run. Looks like that's exactly what I do. Should be getting a dyno sometime soon so hopefully I'll have some numbers for you guys :D
Oh and that swap is too much of a pain for me. Plus I love the shifts with the upgraded valve body and I love not having the BOV go off after each shift. There's also rush hour traffic and a bunch of other extras. I like my auto :D
