- '02 Mazda Protege5
My car has recently started popping out of 3rd gear under acceleration.
It seems to occur more under heavier acceleration but not at idle or cruising.
Factors to consider:
-Grinding never happens during shifting so i doubt it is related to the synchros.
-While accelerating, it is fairly easy to pull out of 3rd without the clutch depressed; but not the other gears.
-The play in the shifter is shortened in the forward throw gears (1st, 3rd, 5th) while accelerating.
-Passenger motor mount is torn, i suspect others might be failing then too.
Could this problem be caused by a worn shift linkage or is it internal transmission damage?
