you should have a high flow cat if you are going to run an AP stage 2 tune
Yeah, I agree with 240ka. Why "should" we have a high flow cat to run that tune?
The tune is designed to have a minor amount of system back pressure.
im ordering my turboxs dp/rp tonight, my friend is selling me his cpe stnadback and pnp for dirt cheap, can i use that instead and have someone tune it for me, or would cobb ap be the way to go
needs tune you will be hitting fue or boost cut and ....you will need fuel pump or internals to run tune Im 100% sure your stock pump wont be enough.....can believe noone mentioned that
well youll run a stage 2 v105 sf map to start with assuming you going the turboxs dp/rp direction. I highly suggest going wiht 1 step colder sparkplugs when you get the AP...Make sure thier gapped .026-.028. Denso ivt-22 plugs would be a solid choice. To asnwer the cost of tune question:....... Like I said before when you your Cobb Accessport,It will come with a cable that can plug in both your laptop computer and car. Read the directions and download the cd into your computer. The database shouldm update itself and you will have all the version 105 maps on your computer. You will then plug the Ap into your computer and download the maps on to your AP harddrive. Once done so..follow the directions on pluging the ap into your car and loading a map into your ecu. so when you plug that Accessport into your car. Your mod list shoud be- cobb sf intake,turboxs downpipe/racepipe,Forge bpv,and 1step colder sparkplugs gapped correctly. With these mods you should download the stage 2 v105 sf map...there are 2 of these maps..1 is for 91octane gas..the other for 93 octane gas..its ok to run 91 map with 93 octane gas..but not visa versa..bottom line if you have 92 or lower oct. run the 91 map..93 or higher,run 93...Now these maps are free,and wont cost you a thing,they come with the AP. custom tuning costs varies...check with your local and RELIABLE Cobb tuner. I suggest datalogging your car's peformance while running the stage 2 map to see how your afr's, fuel psi,knock retard,timing ect are doing before you go out and spend money on a custom tune. I will say that custom tuning is key to making the most power "safely" on this car. Im sure youll have more questions and their are members on here that can help you..this should give you a decent start. Just take things 1 step at a time and follow your product directions and be safe and level headed when your tuning your car.
yeah and no back pressure is the best...all of the tunes are designed for us to use all cobb parts which we dont
no high flow cat needed
you get boost creep w/o a cat
the off the shelf tunes are designed for a highflow cat.
onelsono: That is the suggested spark plug gap from Cobb, as well as having 1 step colder plugs. But if your bone stock or just got intake-testpipe thing goingdont worry about it. If ypou have the Cobb AP..then you need to go with thier specs...or you should anyways...and regarding this back pressure s***...You dont "need" a cat...would it help with the ots maps? YES...cause thier designed from using a dp with a dam hi flow cat. But you can tune the catless downpipes just fine..just keep that in mindhappy tuning.
watch ur fuel, its starting to get colder so the boost is gonna hit alot harder, u done want that thing to lean out at wot and go boom. to be safe u should be in the 11's all the way through the powerband.I have a Corksport down pipe/test pipe with a high flow cat and I'm still running the stock tune. I have never thrown a CEL and the car run great.
onelsono...I got my ivt-22 plugs at my local tuner shop..but Protegegarage has them.
http://www.protegegarage.com/product_info.php?cPath=160_403&products_id=1574
hell yeah...cool weather is coming. so is the Front mount, Dp and FPIs...this is going to be a fun fall and winter
