Todays project...
chuci
MS3
Finally got over it and installed the PG TIP and TRZ Tranny Mount today! All I had planned on was the TIP, yet with the battery box and everything else out of the way, wtf, right? Once I went back to TheDoc's write-up, the TIP wasn't as bad as I thought - it was that stupid little vacuum hose that almost made me cry... :(
"Mr. Rogers, the surgery was successful and we were able to remove the tumors, although it was a bit of a !(&*($^# in the arse!"
Now I just have to remember to keep my driving 'easy' for 50-100 miles for the ECU to reset.
just reset your ecu by disconnecting the battery.
the turbo inlet isnt going to affect your fuel trims like that to where you have to take it easy.
thats something you would do if you chnged your tune
just reset your ecu by discounting the battery.
the turbo inlet isnt going to effect your fuel trims like that to where you have to take it easy.
Exactly. After I installed the Cobb TIP and SRI, I drove it like I stole it. Remember when you remove the battery box you effectively have reset the ECU, so no worries.
Sunday = mod⋅i⋅fy  /ˈmɒdəˌfaɪ/ Show Spelled Pronunciation [mod-uh-fahy] Show IPA verb, -fied, -fy⋅ing.
Use modify in a Sentence
See web results for modify
See images of modify
–verb (used with object) 1. to change somewhat the form or qualities of; alter partially; amend: to modify a contract.
2. Grammar. (of a word, phrase, or clause) to stand in a syntactically subordinate relation to (another word, phrase, or clause), usually with descriptive, limiting, or particularizing meaning; be a modifier. In a good man, good modifies man.
3. to be the modifier or attribute of.
4. to change (a vowel) by umlaut.
5. to reduce or lessen in degree or extent; moderate; soften: to modify one's demands.
Wednesday Night = re⋅pair1  /rɪˈpɛər/ Show Spelled Pronunciation [ri-pair] Show IPA
Use repair in a Sentence
See web results for repair
See images of repair
–verb (used with object) 1. to restore to a good or sound condition after decay or damage; mend: to repair a motor.
2. to restore or renew by any process of making good, strengthening, etc.: to repair one's health by resting.
3. to remedy; make good; make up for: to repair damage; to repair a deficiency.
4. to make amends for; compensate: to repair a wrong done.
Why do I have another pic of the TRZ Mount? Notice a difference from the before pic on Sunday - where was the washer? UNDERNEATH THE BUSHING - yep, I'm a dumass that didn't use common sense. To the credit of the Urethane, it held the engine up for 3 days!
Ken - PLEASE put a simple note in with the TRZ Trans mounts - "Hey goober, the washer goes on TOP of the plate/bushing when installing" (lick)(burnout)
Oh yeah... has anyone else had an issue with the battery box cover not lining up after removing/reinstalling? Mine seems warped and I'm deabating on just keeping it off (top and front/side)...
Similar Threads and Articles
