Post in here if you have still have and running a Unichip.
I want to see who here still has a bucking jerking issue with the Unichip installed.
Normal overboost fuel cut is when it goes over 12 psi past 5000 rpm.
The ones that have a bad harness usually still have this problem even at stock psi boost.
If you still have a jerking/bucking issue only with the Unichip installed and sometimes throws a CEL. You may need this resistor fix.
http://www.*************.com/forum/viewtopic.php?f=9&t=38
