That really is a nice looking wheel. It doesn't look too bad without the tire, but once you install the tire and lower the jack that'll be when you'll have clearance issues. The back of the wheel looks like it almost touching the strut, but it's really hard to tell at that angle.
Just as I thought, it does stick out a bit and the rear will sit flush, if not a little past flush. Which means you'll definitely have to roll your fenders. Lowering might be out of the question, unless you give it some negative camber.
Thanks for the update.
 .  But I drive an MPV
.  But I drive an MPV  ..........  Get some springs from Autoexe from Upgarage!
