Define "weird exhaust noise"
a noise from the exhaust that sounds weird?
dont forget to check blinker fluid levels too, lol(werd) low fluid will set it off too....which means definitely check your level. If the level is withing the ok range then check your rear and front pads. If they're pretty warn then when you hit the brakes you might be emptying the resorvior to the point thats triggering the light to come on...
dorks...
I think it's one of the exhaust hangers that might be at fault...only makes the noise over a bump (speed bumps, backing out of the driveway, etc.) - a little bit of a rattling sound. Will check it later tonight.
I don't think it's broken totally off - just maybe loose or jostled out of place? Luke put grease on the swaybar bushings a few weekends ago - maybe that's why I'm hearing the exhaust rattle noise...I'm not having to listen to the SQUEEK of the swaybar!
some kid trying to sell magazines door to door said my car looks like it tried to copy an evo. and asked me if it was a mazda prototype
thats not all it indicates. it came on as I was rolling to a stop twice, and went off immediately after I let up on the pedal...
I'm going to assume it has something to do with the wrong rear rotors being on my car (ES/P5 I assume)... and I'm also going to hope that the calipers aren't FUBAR. I noticed they were wrong (came on the car) about 2 weeks ago and haven't had the money to fix it just yet. Kinda tight with moving this weekend and all...
your speed sensor could be going too, is it the parking brake light and the abs light?
ya both of mine has been on for like a week now, gonna troubleshoot today actually.
