I hope these help, it's kind of a hard picture to take lol
gonna steal some grease tomorrow at work to grease my swaybar bushings so hopefully that will stop the clunking. Will probably also change the oil tomorrow too.
Paypaled Spicy for the MP3 ECU flash too, so hopefully i get it by saturday.
Sweet thanks! I look to be in luck! I test fitted some 17x7.5 +48 subzero's with 215/45 tires today just to make sure. What size tires are you running?
The rota's I want are 17x7.5 +45 with my current 215/40 tires, so I should be about perfect
yah they do light up. i posted pics in this link
http://www.mazdas247.com/forum/showthread.php?p=4586855#post4586855
post #28318
Did you ever get your doors to close?
Otherwise, today I finished painting my upper trim pieces black from that weird non-matching gray color. Also did the center piece under the shifter and the cup holder flip lid. Looks awesome! The paint's fragile though... the seat belt adjuster caps rub it off if you slide them up and down...use better paint next time? I used PPG sand free and satin black color coat elastomer stuff.
That's the setup I'm running so you'll be fine. can't wait to get my coilovers so I can make this thing look proper.
So...dropping the car off either tommorrow or Saturday morning along with the motor to get it put in...after the last one I am honestly just to depressed to do it again...my mechanic is only charging me $250 which I believe to be very reasonable...I guess it helps that we have gone regularly to him now in the family for almost twenty years now...he is always willing to help us out...timing belt/new gaskets/thermostat/oil pump/water pump all new waiting to be put on it...now it is just up to me to go pick up the car dolley and borrow a truck...
Pics?
haha! i meant that i cant close em bcuz i cant seem to stop lookin at them but they close just fine.
First off I chopped the harness. If you look at the first picture I posted there was about 10 feet of extra wire which I really did not feel like trying to hide. So, I broke out my mad soldering skills and went to town =)
Came out with a almost perfect custom fit harness.
Then just some panel removal and some wire routing and these babies came to life!!!
I forgot to take the plastic off before I took the picture.
More. They really are the perfect brightness!! I mean perfect!!
No more overpowering than my stereo.
And I finally got around to taking some pictures of the Oznium.com LED panel light output.
Talk about bright!! 30 second exposure f/3.5 ISO 100
