I'm interested to see how these hold up and if you bottom out at all with the added weight.
Well, it's certainly not a performance setup. If anything, it's a downgrade.
Thanks for the encouraging words fellas. I don't see how putting mazdaspeed springs on is a downgrade in performance, Sounds like a bunch of haters to me.
(fu)
(fu)
Alright, I'm a bit confused here, I was reading the posts that were written, and some of the posts say that, "Mazdaspeed" does not make any lowering springs for the MS6.
But on teh Mazdausa.com website, it shows some lowering springs for the 06-07 MS6 that lowers the car by 37mm.
So how come people are saying that they dont make springs, I'm confused here.
I called the parts the department to confirm this, they said that there are 2 different parts numbers listed in their system, one for the 6cyl , and one for the MS6.
It's 2 different part numbers for 2 different parts.
These springs are listed at 300 bucks. So you got them installed for 500 buks (part and labor). I cant remember what my service center said, Im not sure if they said 540 for the labor, or they ment 540 for parts and labor.
Going straight to Mazda and looking at their MS accessories, you'll find this link offers the springs for the 3.0 & MS6. GRMS-8M-H14 is the part #. They show it posted twice listed two different ways, but they are the same part # for both.
Basically, the MS springs are Eibach rebadges IIRC, and if you cross-reference Eibach's suspension options for the 6 and MS6, you'll find out that the V6 and MS6 springs are indeed the same part # as well for Eibach.
If you're truly looking for a MS6 only spring setup that will be stiffer than the stock MS6 springs, look at the AutoEXE, RPM Street/Sport, or H&R springs.
Interesting! This conflicts with the majority of, "know-it-all's" on this forum. lol!
(uhm)
Survival of the fittest. I say let stupid people make stupid mistakes.
I try to provide people with information based on things I may have researched. Since I just did a spring install, I looked at all possible options and read reviews, pricing, etc. If you don't want to listen, go for it. Don't come on here and b**** when something isn't right and it was told to you from the get-go. Sometimes the 'know-it-alls' actually aren't talking out their ass.
(fu)
If you're looking for encouragement, look somewhere else. I don't encourage bad suspension engineering.
It's quite apparent that you don't see why what you did is a bad idea, so let me educate you:
This is a photo showing front shock travel for the Mazdaspeed6 (left), 6s (center), and a Koni shock (right).
Note a couple of things: The MS6 shock travel length is actually less than the regular 6 travel.
So, the MS6 has about 5.5" of travel to start with. But, recall that there's a bump stop in place. The bump stop occupies 3" of height, so that leaves you with 2.5" of travel. Based on the heavier weight of the MS6, your suspension drop will not be 1.5". But rather, it will be closer to 2". Subtract that from 2.5" and you'll only have 0.5" of front shock travel.
5.5" travel - 3" (bumpstop) = 2.5" suspension travel - 2.0" drop height = 0.5" final suspension travel.
0.5" travel is not necessarily bad, if you have increased spring rate to counter suspension compression. But, the problem is that you're actually below the spring rate to prevent that from happening.
If we use a 6s spring as a baseline for spring design for the Mazdaspeed6, it would be:
- 25-30% stiffer to account for the added weight of the MS6.
- For a drop of 1.5-2.0", I would be looking at another 20-30% spring rate increase to prevent bottoming out.
The Mazdaspeed spring for the V6, only does one of the above - leaving you with an undersprung setup.
When it all settles, you'll be left with little or no suspension travel on a softer suspension setup - recipe for bottoming out.
Suspension travel is king. If you don't have room to travel, the suspension is not working.
And, I haven't even begun to address the differences between the sedan springs and the hatchback springs! God help you, if you have the sedan springs.
That's not hating. That's just plain and simple Engineering 101.
Feel free to counter my argument with the same amount detail and explanation.
