Ok, did the front wheel bearings a few months ago, roaring is still there, except no longer in the front, in the back...
Vato-Zone says there are two different rear "hub" and bearing assembly's for a 2002 Mazda Protege. One for "anti-lock brakes" and one for "drum brakes."
Well, technically, I have neither, or I'm under that impression...
2002 P5 with rear disc's, but not anti-locks.
Which do I need? The picture (which may or may not be of actual part) shows some splines at the end of the hub for the anti-lock, and no such spines on the drum...
$99 each for anti-lock, $40 each for drum.
Thanks!
PS: I had the car aligned after the front bearings were done, will she need to be aligned again? Not messing with the front at all this time...
Thanks!
