Ceramic Coating Turbo Manifold?
Ninkumpoop
2009 Mazda Mazdaspeed3
I'm getting a "Tubular Turbo Manifold" for the Speed3 from protegegarage.com and I was wondering if I should ceramic coat it. I was told to wrap the wiring for the O2 sensor to protect it from the heat of the manifold but what about ceramic coating the manifold?
Ceramic coatings not only look nice, but they help hold more heat inside the exhaust which adds power. This would seem especially true with a turbo car as heat helps spin the turbine. If the manifold is only mild steel, it will look better, last longer, and perform better with a good ceramic coating.
I would certainly do it, and I would ask PG about having them do it for you if possible.
