HondaEat-R
Turbolife gained HP over the Perrin.
Last time I checked, the Turbolife was the same as the Perrin.
i think that intels wrong soldier...
turkey is not produced by the intake.... its amplified by it
i still dont see how two identical intercoolers can have different power gains....
Lets see... Two companys make the same thing... But the gains can be different because the material made and how its made. The Turbolife gains more then the perrin, and theres dyno sheets that prove it... Just cause 2 things look the same doesnt mean they react the same. The turbolife gains more ok people? GOSH Thats all you need to know...... Its not rocket science, and anyways, its only like 5 or so HP isnt it....
Turbolife was running the Perrin on the stock dyno pull, then he swaped over to the Turbolife and made HP.
Dyno Sheet (Perrin run in blue, Turbolife kit in red) -
See, tahts the numbers he made.... The only difference is the manufacture of the core. the core turbolife used must be better then the perrin's core, thats all I can think of.
its the same design, just different cores..... Gosh you people are thick sometimes LOL
then PM justinlansdale and see how he likes his Turbolife Kit...he says it magic. Im telling ya man, the turbolife is great. Theres someone else on here that switched from the perrin to this.. If i remember his SN ill make him get in here aswell.
We just like to make decisions for ourselves, and not be so susceptible to the powers of suggestion.
Looks like the Turbolife ran more boost and slightly leaner AFR's than the Perrin...
Turbolife said:Input labeled "ANALOG 2" is boost pressure. As you can see there was a slight boost spike compared to the Perrin run @ around 2800 rpm. This accounts for the surge in torque @ its peak (227 vs 218).
Also, for a 'lil while there the AFR's are like 13:1. Yikes brother, lean much ?
I'm a skeptic in all aspects of life, and because of this I'm not easily impressed when the "manufacturer" of a product posts dyno sheets claiming their product is superior. A truly unbiased comparison would be from someone that's not affiliated w/ Turbolife, thus has nothing to gain from results of the tests. I know, I'm crazy.
