Went to Elite at lunch to pick up some parts I'm selling off, and took a closer look at some of the parts and DAMN are they ever pretty
The block, bored. The rust is still "there", but it was acid dipped so once the block is reassembled and sealed off, a wire brush and some engine paint will make it look gorgeous!
Balanced rotating assembly (Crankshaft, rods, flywheel). Notice the very small nicks on the bottom of the rods, as well as the ONE spot on the lower left of the flywheel.
Intake manifold and throttle body thermal gaskets:
A first look at both sides of Focus' cam gears:
The head just about ready to be dropped in once those cam gears are put on the camshafts (I forgot to take a pic of the underside of it where the little chips were seen, but that's probably a good thing seeing as the camshaft bolts weren't tightly secured and I wouldn't want to mess something up, especially since it was still partially wrapped).
And finally, a GREAT look at the port&polished intake and exhaust ports all cleaned up...
