pulled the trans and paid $2400 to have it rebuilt! lol
But I had no 1st or 2nd anymore. I couldn't even force it in anymore.
Need alittle help. I have trouble shifting into 2nd. Its like i got to force it in(no girnding tho). It also happens a little when i shift into 1st. But the rest are fine. I was thinking i could be the motor mounts. Any suggestions?
I got the same insert setup as you(f/r/sides). So im not the only one with this issue.
Im thinking about getting the damper thing that StealthWyvern got. That might help. Its really annoying when driving in traffic.
i think its one of the quirks of these transmissions. kinda like how it refuses to go into reverse sometimes.
i found out today that the oil feed line for my turbo is leaking badly. it is dripping on the downpipe and smokeing really badly. its embaressing.
^^How bad is the vibration with the Medieval mm. Is it as bad as the awr or su? You dont even notice the vibration with the inserts.
Installed BC coilovers yesterday. (thumb)
^ you just need a new "o" ring on that fitting probably.
