What spring are you using . . . you should hear the ping. Although your ecu is still adapting.
Looks good to me. Any straighteners inside that thing for the mass air sensor?
I only took a quick drive around the block, mainly listening for anything out of the ordinary. Will post impressions from the drive into work in the morning. Not really as loud as I thought it was going to be, and I can hear the whoosh when I shift gears, but no ping from the forge. Not sure if thats normal ?
I can't imagine that heat shield does a whole lot. Look at the gap at the battery box for example. All the air rushing through the nose of the car at speed, then down through the TMIC is going to blast right through that gap I'll bet.
