Vacuum Or Boost: Which is more important?
11 MS3 Sport
So I did some testing and had some thoughts today with my Forge BPV.
But, i'd first like to explain what I understand to be true before I put those understandings into reasoning:
The stock BPV is meant to allow the appropriate amount of compromise between Vacuum and Boost. Besides the fact the stock BPV can/will leak, the stock bpv will allow for a safe amount of Vacuum. I understand that Vacuum is a good thing to have and with this situation, the more the merrier because you're allowing air to recycle and recirculate to the intake whenever you are basically NOT running Full Throttle/WOT/or running hard (for those technical people who will say our cars don't run 100% throttle.)
My understanding is, you'll want to have the same or more similar amounts of Vacuum so that you arn't overworking your turbo on lower load amounts for no reason, nor do you want to keep the BPV closed more often than it's should be, since that's basically what's happening when you have less Vacuum.
OKAY, so here's what I did:
I can't honestly say I remember what Boost #'s I seen with the stock valve, as I didn't ever really pay attention, but I will say I did notice -20 to -22 in Vacuum. I installed the Forge BPV recently with a blue spring and 2 shims. This instantly changed my throttle response to a much more aggressive tone. Power came on more violently at first, but the car didn't not pull any harder or faster. Depending on the gearing or the temperatures, i'd regularly see 14-15psi, but my Vacuum #'s were less. OFF throttle, i'd have plenty of vacuum, but during part throttle cruising, I actually had less Vacuum. Anywhere from -14 to -10 Vacuum in similar speeds. This concerned me because I also noticed that the valve would release at part throttle but it would shudder if I was starting to ease off from hard throttle. It would almost hesitate or not want to release pressure at all unless I was lifting OFF throttle completely. Boost was ON/OFF/ON/OFF instant like a light switch but I still did not notice as much Vacuum in normal driving or cruising like I did stock. SO, power would come quicker, but it wouldn't pull any better than stock as the turbo's already spinning to it's max. At this point, all I can do is wind out the rpms.
I finally decided to switch to Yellow + 2 shims today. The car drove completely different! It was definitely less violent, no shuddering between part throttle to little throttle after a hard push on the gas. And my boost #'s were still 15-16psi averages. What I also noticed was the turbo lag was more noticable (still seems completely acceptable and perfectly safe and normal). The car would take a second to build boost but when it did, it would lurch forward in that "stock" type of thrill I enjoyed experiencing when I first got the car. Vacuum #'s were absolutely acceptable and back to stock, and the car felt great to drive. I will say however, the trade-off has been more throttle required to leave from a stop. Makes sense, considering the Blue + 2 was closing quicker and wanting to build boost faster to assist the engine.
Ultimately, I can't decide which is better or safer. Having a wild child, aggressive spring setup is awesome because of it's Instant-On/OFF response. It doesn't build bigger boost, but it builds boost harder, sooner and much sooner. What I can't translate is whether I need or want turbo assistance for every instance of driving. Technically, the turbo is supposed to be compressing air into the engine during WOT/hard throttle. Utilizing the turbo for so many situations seems like an easy cause to strain and cause damage.
Then again, the yellow spring seems to react no different than stock other than it's capable of holding boost more consistently (although when I drove tonight when it was 10* colder, I wasn't seeing 15psi anymore). So...those are my thoughts. I appreciate any helpful contributions to this thread from much more knowledgable turbo guys!
i believe my vaccum is around -20 and my boost is 15.6. i have the Greddy Type S Bov. all works perfectly
Have you serviced your Forge BPV? I had no idea it had to be serviced and finally did it after about 20,000 miles with it on. It made a HUGE difference.
I have always ran the blue spring and noticed now it is a much more smooth boost delivery and less of the instant on/off type syndrome you are experiencing.
I have anywhere from -20 to -25 vac at idle and boost will hold strong between 15-16PSI.
how do u service the bpv?
Maybe Patty can come in here and comment on this. I'm under the impression that anything less than 20-21 vacuum at idle with accessories off indicates a leak somewhere and shouldn't happen regardless of whether or not the BPV needs lubricated. I could be wrong of course...
For the record, I have only mscai and forge. I just bought the Forge so its brand new. However, I have heard people regreasing the bypass valve from the manufacturer and having it work much better.
I have contemplated the possibility of a leak somewhere but can't fathom where it would be coming from. Sounds like I need to possibly re-align the mscai couplers, or check the turbo inlet.
Oh I think I misread your first post. If you said you saw 20-22 at idle with the Forge than yeah... there would not have been any leaks.
just to sub this thread and add my own numbers for further information. im pulling the 15-16 PSI on a stock tune with quite a few bolt ons. i have the forge and i think my vacuum is also roughly 10's or close to it. i didnt have my ap before my bpv but the wierdest thing happens to me. electronically through my obd-2 it reads 10's for vac. my mechanical boost gauge reads 19 vac. now trusting my ap i believe it is 10's but i never got around to adjusting the springs around the blue to see if i got any different numbers. i figured the 10(+,-) vac was "normal" with the forge bpv. id like to know the answer as well so i can make adjustments accordingly. thanks.
i have a forge as well. bought it new from SU. other mods are SRI and turbo inlet. i got a dashhawk earlier this week and been monitoring my boost psi. vacuum was -21 or so at idle. but the most boost i got was 4-6 psi unless i went WOT, which would spike to 16-18 psi. i checked all my hoses and clamps for any leaks and noticed nothing wrong. so i put my stock bpv back on yesterday and my boost is MUCH better. i think whoever greased the forge from the factory went a little overboard with it. i've cleaned it out and regreased it but haven't got a chance to put it back on yet. i plan on doing so tonight, hoping that the gobs of grease in it was what caused my lack of boost pressure.
I noticed the same issue when I first installed the Forge BPV. It wasn't hitting the outrageously fantastic boost #'s that everyone raves about. But I honestly think temperature had a lot to do with it. Once it warmed up, I was easily hitting 15 psi when it was 50* or higher.
If you search on the other forums, "How to service Forge BPV", you'll find a thread by freeflyfreak. He wrote a great article and linked some help in pdf formats.
I've been playing around with boost at part throttle. I don't like the fact the car doesn't leave from a stop as easily as before. It's very hard to judge what the car's doing, almost how I felt when I didn't have a rear motor mount.
I'm NOT interested in swapping back to stock, but if I have to, in order to get some concrete data, I suppose i'll have to.
Ultimately, the weather temps need to stabilize and I need some time to do some runs around town. This 30*-40* stuff is messing me with me big time. Erratic #'s all around.
your gauge is reading in inHg and your AP is reading in PSI
Here's a couple of datalogs from my DH. Mods are CPE nano and HTP turbo inlet.
Stock BPV
Forge w/ Blue Spring no shims
so hg is relatively close to double psi. thus making my vac. of 20(+-) on the gauge, 10(+-) on the ap. i watched my logs carefully between WOT with a psi of a solid 15-16, to idle vac pressure of, at max, -12. usually it was holding a -10.4 vac.
anyone come up with any conclusive ideas?
so far it seems like we all should just rip them apart, clean them, and just regrease them ourselves.
No one seems to help so far. Guess I had a good question.
When you're data logging, you should log Engine Load as well. That's going to contribute to the vacuum #'s. Your Forge #'s are good but your throttle is at 0, versus 13 on the stocker. So even though the engine is turning, it's at 0, which will always show a rather decent vacuum, although if you LIFTED off the throttle, it should be over -20 Vacuum. I'm going to try and pm Patty and see if he can be of any assistance.
Ok, cool. Thanks for the acknowledgement atleast!
Here's another theory of mine:
I noticed today while driving that my lower vacuum #'s with the yellow spring are greatly affected by very minor changes in throttle position. IE, I could be cruising on the e-way at -15Hg, but as I barely easy into the throttle, it dips to -9, to -7Hg. So the valve is incredibly fast to react to the changes in throttle, even with the yellow spring.
However, with the blue spring, it's already in the power practically, so throttle changes don't make much of a difference from what I recall. Either way, I may seriously switch to Blue + 0 shims and see if that's the best compromise.
Also, i'm going to be running my Dashhawk on 2 Bar graph, monitoring Boost/Vac and Calculated Load. Then i'm going to try and compare the pressures in comparison to spring and temperature within the next couple days over the same strip of road. I'll report back!
