bonack speed 3
- mazda speed 3
what size tires should i run on a 18x8.5? any thoughts or ideas would be helpful thanks
Offset will determine what size you can run.
it is a 44mm offset
it is a 44mm offset
That wide and that small an offset? I don't want to think about how far those are going to stick out in comparison to stock. Rolling may not be enough, especially if he adds lowering springs to the mix at some point.
so would that be to wide? should i just go with 18x8 then?
Up to you boss. The tire will be your problem, not the wheel size.
