Lil_vicious559
Banned
- Mazdaspeed 6
Research indeed.
I can see how this might be a problem with say a motor with a throttle cable and a distributor with mechanical advance. It simply doesn't make sense with the level of timing and engine control in the MS3. Hell even a 5.0 mustang ECU can pull timing if you go WOT at lower RPM.
What exactly is going on? Are we talking too much timing for the throttle position and the ECU just screws up? You're not making any boost at 2500 and it's just kicking in at 3K. The ECU can read that boost, so what's it doing? Does anybody have any DH data showing KR?
I would attribute that motor failure to the modifications taking the engine parameters outside the control of the ECU, not any fault of the ECU.
Otherwise you're telling me Mazda missed the boat, screwed up, and left something on the table when they designed this car. It's a great car, just don't press the gas to the floor below 3K rpm or you'll throw a rod. WTF? With mods I can believe it but STOCK..not buying it.
Regardless of how it happened or what you don't understand. Why would you or anyone want to stay at 65mph at 2500rpms and floor it. That's STUPID, you can downshift to 4th and have plenty of RPM'S to go WOT.
(uhm)That's like passing car's on a 2-lane highway trying to past a car at 65mph in 6th gear = FAIL
What you're missing here is, that when going WOT at too low of speed/RPM's . Too much boost is being build up and spooled. Causing the ECU too Probably Override reading (OVERBOOST)
