novacircuit
- mazda, speed3
***Final Update***
Just an FYI for anyone that has similar issues in the future and looking at this thread. The tech at the dealership had called and told me he replaced the fuel pump and purge solenoid valve... so I assume these parts were causing the issue. Turns out, as soon as I turn on my car to leave the lot it stalls at idle twice... I talk to a different tech that is more up to date on the speed3s and he tells me to bring it back. I bring it back and he replaces the front O2 sensor (as I originally assumed.....) and cleaned up the spark plugs, which was interesting because I had just replaced them. Maybe dirty from running so lean? But anyways just wanted anyone looking to know these were the symptoms I got and the issue with the car.
**Update**
So since my car was still considered under warranty with it only being an 08 and only 12000 miles i took it to the dealer service dept to see if they'd honor the warranty with the intake and bov on. Turns out they are pretty oblivious. They said they couldn't get in the ecu (AP), since i forgot to unmarry like an idiot, and i came up and uninstalled it at the service dept.. anyways they found out it was the engine pump failing... so how does an engine pump fail from just an intake??? ridiculous... and as for the ap i had the issues with the pump before i installed ap so the ap didn't cause the fuel pump issue. So my question, should the new pump be pretty solid for a few more mods or are new internals essential? i was planning on getting them pretty soon anyways but just seeing what everyone else says.
thanks
**EDIT** UPDATE**
Okay so I'm still having some pretty serious issues. I fixed the line and there are NO leaks. I pressure tested and everything is clamped up tight. When i cold start my car will stall and idle extremely rough for the first startup, but every other startup is fine if the car is still warm and after i drive it for even the smallest distance the idle is fine. My car putters out in low rpms at times (at least once each drive) under 3000rpms. OBDII scanned and got these coded:
p2177
p2187
pending p2177
pending p2187
pending p2097
pending p2195
the first two are engine bay running lean and lean at idle and the last two are front oxygen sensor issues; however, since they're only pending i feel like the first two codes are causing errors with the oxygen sensors every now and then.
Like I said before I only have the cobb sri. Could the sri be throwing off the sensor and screwing with the afr?
Any help would be greatly appreciated.
Thanks.
[Old First Post]
I recently installed the cobb sri and a greddy type s (recirc of course) on the speed3. At first there were no issues but i realized later i forgot to modify the hood or rotate the bov to fit under the plastic hood molding and now theres a hole in the turbo tubing to the bov. I tape this up about every other day (doesn't hold long...) until my silicon tubes come in. Now, a couple days after the installs i get a check engine light (around the same time the hole was created) and at startup at idle the car will putter out and shut off. This only happens right after startup and after i drive and am at idle at a light or something there are no issues. Also, every time I drive the car now i get fuel cutoff at least once. Any help or suggestions? thanks.
**Update**
thanks
**EDIT** UPDATE**
p2177
p2187
pending p2177
pending p2187
pending p2097
pending p2195
Thanks.
[Old First Post]
