Petesspeed
- 08 Mazdaspeed 3
Well got home and decided to install the package sitting on my front step. not to bad of install a little tight to fit everything behind the radio. 1st time LC display did not work, Swapped wires on blue tooth module, display worked then. No place for factory Sirius to plug in so no Satellite unless you by the XM Navigation unit. Started messing around with it, radio reception very poor, no Am at all(I can live with that I guess) went in grabbed a DVD (WANTED) threw it in, After figuring out about the brake switch hook up finally got a pic, NO SOUND. I try everything no luck. then I try the blue tooth, Call home they here me I don't here them. Needless to say Its back in its box heading back. I guess the LCD display is not that important you can still see the a/c position on the switch, guess I will go by an Eclipse Screen. Always had good luck with. Sorry didn't even take pics. Didn't match a/c controls anyways.
