How-To Corksport testpipe
954_ms3
2008.5 metropolitan gray
Anyone have instructions or link on how to install the testpipe, left the instructions about 300 miles away (bang).
haha it shouldn't be more than unbolting the 4 bolts and then removing stock and then putting in testpipe and bolting it back in.
you would "THINK" that, but its a little more involved than that, but its pretty self explanitory once you get under their
lawl i figured that much. i'll be more specific, springs, bolts, and washers?
alright going to go attempt the install now, if everything goes well expect a vid
remove that cross member below it for more simplicity, 4 bolts I think.
wish i would have done this from the start but i didn't. anyways the install was easy, took maybe and hour or so. only problem is i can't get it to not leak. it mates to the stock downpipe perfectly, but the exhaust doughnut that's supposed to mate to the stock cat-back is poo-poo. oh well what can you do, i'll eventually get the exhaust depot downpipe since they're about 20 mins from my place. vid will be up in an hour or so
nice avatar btw maestro. i feel like half the people on the forums wouldn't know what movie thats from
This is a very basic install. You could do it in about half an hour. Make sure your gaskets are good, and just unbolt the stock unit. The new test pipe should fit right into the same location and bolt right up...
Edit: Did you reuse the stock donut that was on the midpipe? I used a TXS gasket and the stock donut (it fits into the cutout flange on the new racepipe/midpipe, then that donut will fit into the CBE pipe to make a good seal...
