evo 9 enkei rims
Should fit, but like CnoTataymo said, there may be some rubbing in the rears. Same bolt pattern though.
i have 18x8 38 offset and 235/40 tire on stock suspension and it dont rub so i think if its 17 inch rims you should have any problems even if you are lowered
Cool, but you asked him why. That's what I was responding to.
Luckily for him, I believe the Evo 9 bore is 67.1, which is ours, too.
Good deal! I didn't think many other companies used that bore size. I did notice that the offset seems a bit low (+38). Stock is, what, +52? Make sure that's not an issue either...
