STOCK BOOST questions
AMS38U
so i put the cobb sri and turbo inlet on and i kno boost in 1-2 is cut due to the traction control but in 3rd and the rest of the gears what is boost supposed to be i noticed that i wasnt spikeing the 20 i useually do in third it was only hitting like 12 or 15 does ne 1 have a log of what the boost should be from a dashhawk
Where are you located? These cars like to drop boost in cold weather it seems.
Other than that I would just double check for leaks.
Mostly where the clamps are, maybe a vacuum line is loose. Just recheck all of the different fittings to make sure that when they are under pressure no air will be leaking out.
Gmac
Turbo inlet... Loose on most MS3's.... Apply some pressure in/out to it. You'll probably be able to move it around with some pressure....
i just put the cobb inlet on so im pretty sure almost positive i put it on really tight i guess ill recheck it all though prolly check the intercooler hoses also
