3rd Gear
3rd Gear
4th Gear
4th Gear
OK. So I've been doing a bunch of logging recently while dialing in the SS Map clamp. The first one looks OK. The second does not, but no boost cut that time. 3rd log was in 4th gear and I hit one boost cut. 4th had no boost cut, but it looks like crap. Mods are: MSCAI, Forge BPV (blue spring with 2 shims), SU boost tubes, ETS TMIC, SS Map clamp, CS DP & RP, and some suspension and rims. I definitely will be getting a fuel pump next, then probably a tuner of some sort.
Thoughts?
3rd Gear
4th Gear
4th Gear
Thoughts?
