What to do?
go with the inlet im stoked to get mine get theres a group buy for one in the for sale thread, 188 shipped and there are alot of good reviews on it
i haven't done one yet...the only problem i foresee is getting access to the turbo.
take off the battery and battery box and it probably won't be that bad
Yea that snail is hiding WAY back there. I would think the TMIC would have to come off as well.
And can someone please tell me if the TRZ rear and tranny mount package would put my "will my motor fall out?" worries away for good? I'll start crying soon if not.
installing an inlet is no harder than an intake install. as for the mount combo, i've never had an engine drop on the combo since we started selling it. i'm confident the ability of those parts, and TRZ is working on a replacement bracket for it to further beef it up.
Hey philly if I get the standback do i have to send my ECU to CPE? Also is it easily flashable back to stock for dealer visits?
if you get the standback, you hook it up to your ecu and don't have to send it anywhere. if you're worried about dealer visits, then i would also recommend the pnp harness to make it very easy to disconnect the sb from your vehicle. i don't think they can check at the dealership to see whether or not anything has been hooked up to it.
the sb comes with a switch and a bypass plug. the switch will allow you to switch maps, meaning you can have two maps loaded on the sb. this means you can have a "stock" map as well as a tuned map. or you can tune both of them, one at 16psi on pump fuel, and then one at 124781289 psi and race fuel.
the bypass plug will allow you to completely bypass either map and run off the stock ecu. again, if you're worried about dealer visits, i would recommend sb and pnp.
THEN, on top of that, cpe offers some flashes, which is what you're talking about like the fuel cut and full throttle flash. BOTH of those require you to send your ecu to them.
i hope that answers your question(s)
If you are planning on offering the rear MM + tranny mount with revised bracket later this year I'm all over that.
i'm going to be offering it with the passenger side mount as well within a month's time. complete engine mount set for 275 shipped anyone?
hey i moved to round lake, so i'm farther away now ;) pm me, we can work something out
